Melt it down into a cube, grind away everything that isn't a Garret turbo 50 series or greater.
The stocker is a pain, and almost not worth the effort. People have ported the inlet, ported the outlet, port matched the inlet of the exhaust housing to the exhaust manifold. Some port the wastegate for better boost control, but I don't know of many with any amount of good success here. The exhaust section has a big mismatch, and may be the area you gain most.
My opinion - it's an undersized turbo, its worst feature is that your boost is out of control with it most of the time. If I had a truck and HAD to keep the stock turbo, here's what I'd do:
1- get an external gate
or
2- run it with the cat on all the time
I think you will go insane if you go for max effort out of the stock turbo/wastegate, get rid of any intake/exhaust restriction, then expect any amount of control out of the stock turbo/wastegate. Some have done it, many more have had problems.
IMHO, going with a different turbo is a safety issue on a modified truck. Cooler air charge, controlled boost that you can rely upon.
