monitoring datamaster pic
tydye
Banned
Re: monitoring datamaster pic
I see a couple of things in the first two screens. Both regarding idle. IAC counts are high. Should be 15-20. You have 40 & 54. Adjust the throttle-plate idle stop, or bend the lever until you get 15-20 counts.
Then adjust the TPS to achieve .5 Volt. Right now you have .78 & .80 Volt. There is opinion that best results are with TPS at .5-.55 Volt at closed throttle. You may have to elongate the mounting holes to get enough range for adjustment. Or adjusting the idle stop above may get the TPS closer too.
That's what I see.
cool, appreciate you taking a look!
turbodig
Then adjust the TPS to achieve .5 Volt. Right now you have .78 & .80 Volt. There is opinion that best results are with TPS at .5-.55 Volt at closed throttle. You may have to elongate the mounting holes to get enough range for adjustment. Or adjusting the idle stop above should lower TPS too.
Not to pick on you, Dave, but this is completely unnecessary. The software in the ECM corrects for minimum and maximum voltage and creates a % TPS variable based on that. That's why they don't have adjustment slots from the factory. If the voltage was *way* off, it would be an issue, but .2-3 isn't crazy.
Unless you don't see 0% at minimum throttle, there isn't a problem.
I suspect a lot of the "adjust the TPS" mythology is a GN crossover... TPS adjustment is very real and necessary in their systems.
What I do sometimes find, with higher than normal minimum voltages on TPS (and other signals), is that the grounds on the back of the driver side head aren't clean/tight. This makes the ground reference "float" a bit, and pulls the minimum voltage up.
Also could be a slightly bad/dirty TPS, right in the idle area where it sits a lot of the time.
