More Boost
Sean Krupa
Moderator
I'm having a hard time getting the Boost at 20psi in 2nd gear. With Code59, I've been adjusting the F71 and F70 tables. I even turned my WG rod 1 turn to see if that would help. 1st and 3rd gear, I pretty much have 20psi which is my target.
I had the F70 table at 20psi target. I changed it to 21psi and no change. I still have some room to adjust the WGDC in the F71 table but DM shows the WG is 100% closed most of the time. I even verified the WG isn't sticking when hot.
Anybody familar with Code59 please chime in. I want to go to the track Friday.
Thanks,
WyoSyclone
Re: More Boost
Hey Sean,
It would be good if you'd post another graph showing WGDC as one of the graph lines... the other guys could see what I've done with your WGDC to try to get it where it is.
The other thing that will help the other guys add some ideas is to let them know I took some timing out at that point trying to build a bit more heat in the exhaust manifold (doesn't look like it did much good).
Hopefully Dig and Jeff will see this and give some input.
sy#2716
SyTy 4 Life
Re: More Boost
One thing that i see is that you are running out of injector. Look at the inj duty cycle. Anything over 90% means you need to set up to a bigger set of injectors.
I know that doesnt help with you boost question.
WyoSyclone
Re: More Boost
Yup, since we started tuning Sean's truck we've been running on the ragged edge of not enough injector... we've hit the limits of boost and timing with these injectors.
turbodig
Re: More Boost
Sort-of.
With stock injectors, I had 108% , added fuel, and it got richer.
No disagreement that it is the bleeding edge of fuel for the stock injectors. Really big boost and low 12s/high 11s on stock injectors means 60 psi base fuel pressure or thereabouts.
turbodig
Re: More Boost
I would like to thank Rob for all his help. I wouldn't have got this far without him! :tup:
OK... looking at this file, 2 things are going on -
Your WG DC resets at the shifts are a bit low... you can see it trying to step up boost (WG DC) after each reset.
The other thing - looks like you're getting a fair amount of flapper blow-open. You can see this in the fact that WGDC is at 100%, yet in second gear the boost drops off.
First thing I'd try is about 2 turns on the WG rod (tighter). If that doesn't do it, I'd look into an exhaust restriction. Stock turbos you can generally get 22-24 psi without too much trouble... sometimes more.
It's possible, also, that an overfuel is causing the boost to drop off. Leaner mixes make more boost, richer makes less, even with the same DC. You can actually "control" boost with fuel.
WyoSyclone
Re: More Boost
Thanks for looking at that Dig. We had the WGDC resets up higher but got some pretty bad spikes during the shifts. Where we are now is an attempt to get a pretty smooth boost line. I will bump up the WGDC at the 50mph a bit - I can see where we're dropping a bit of boost there.
We'll have to try tightening up the flapper. The exhaust/turbo mods are making this one a bit tricky to behave on the boost side. No cat, ported turbo, and JSM downpipe are moving a bit of air.
We're already running a bit more lean than what I would like, and I'm afraid of recommending any leaner when it's not my motor :)
I tried retarding the timing a bit to throw some more heat in the exhaust but that didn't seem to do much.
Looks like a bit tighter on the WG rod and bumping the fuel pressure are our two remaining experiments.
Thanks for putting another set of eyes on this one Dig... I'll post the BINs I've been working on for a few guys over on the '59 site once we've completed our tests.
Sean Krupa
Moderator
Re: More Boost
Thanks Dig! I will try another 2 turns and another 2psi on FP. I'm still going to the track Friday for the last time this year to see what I'll get out of it.
This winter I'm planning on upgrading injectors along with a couple other mods.
Thanks,
Re: More Boost
Put a external helper spring on the WG arm to help keep it closed as a test.
100% WGDC and low boost tells me as Dig said your blowing flapper open. Its not a boost controller issue but mechanical or something else.
turbodig
Re: More Boost
Thanks,
Was this with the alky spraying or did you just have lots of octane?
Alky and stock injectors at 55 psi base or better should be enough fuel for very low 12s or high 11s.
Spring rate becomes a problem at 20 psi and above. You can work around it with rod tension up to a point, but it eventually catches up.
turbodig
Re: More Boost
One thing I've been looking into is putting a delay time after WG init reset.. The code tries to correct to the target immediately after the reset, but the system hasn't generally even reacted to the DC reset yet.
Letting the mechanicals catch up for .5 sec or so would keep the system from overreacting.
If the alky's running, you should be in good shape that way... you might want to turn up the initial on the Alky kit if you're getting to the edge of fuel.
Sean Krupa
Moderator
Re: More Boost
I was running a 50/50mix of Windshield washer fluid and Heet. On the last couple runs, we added more Heet and almost at a 100% Meth solution. I have the FP at 52psi.
I tightened the WG 2 more turns and the boost didn't change. I also messed with the F71 table and no change. I'm going to try an external spring to see if that will help.
PS- my WG rod is about half way with the center of the Flapper.
Thanks guys
