More datamaster questions
gstacky
Hey guys, I'm just learning datamaster and have been doing a few runs today. I have a few questions. Just so you know, I have a 20k mile truck basically stock, and just did the silicone vac kit.
First, Boost tgt psig reads 6.5, is this right? I was thinking it would be higher, and boost builds to that but no higher.
Second, which is good I think, I am showing 0.0 spark retard, and my knock count is showing 414 and 1. Not sure what the 2 values mean so if someone can explain that to me.
Third, what do the LTerm/STerm values mean?
Fourth, under some acceleration, the EGR values turn yellow and the numbers go up, is this normal?
Any help is appreciated, just want to make sure everything is the way it should be.
Greg
bezerk
Re: More datamaster questions
boost tgt isn't really somethine that shows important info.
the knock counts are only usefull in the older datamaster versions, with 0 Kr i wouldn't think the deal of it.
Sterms and Lterms, i think it has something to do with the ECM trying to reporgram it's own feuling,. but there are other things in datamaster that show better things.
the yellow and EGR is normal on a stock truck.
look at the Iac counts, should be around 30-40. (vacuum leak if higher mostly)
under WOT Mv should be in the 900's or high 800's
look at your IAT temps. if they are high you need to check your intercoolerpump. also a good thing to hotwire the pump.
gstacky
IAC stays between 61 and 66, is this a problem?
IA temps were around 160 or so at the most and that is without the pump on, I forgot to flip the switch that has the pump hot wired, I'll make sure that is on next time. FYI truck was running at 189 when the IA was 160
bezerk
160 IAT is way to high, make sure you don't have to flip the switch, it's not bad that the pump runs more than it should. forgetting to turn on the pump will cost you a new engine
WyoSyclone
Greg
Go into "setup", then "display units"..... set the 'map calibration' to "OEM"... that will get your boost to read correctly. 'Boost PSI' is the one you want up on the display.
gstacky
It was set to that already, I clicked off it, then back on OEM, so I'll see if anything changes
gstacky
I wish this was around when I started learning DataMaster.
http://powertuneplus.com/syclone/tunersguide_dm.shtm
That site is pretty informative, thanks:tup:
One thing I read on there is to go to WOT, not half ass it, as half assing it can be hard on things. It says that the throttle plate needs to be wide open and if it's not they it can cause some strange noises and backing up pressure in the turbo. Is this accurate? I am a little nervous and haven't got to WOT yet, do I have anything to worry about?
What are the two knock counts, Knock16 vs. Knock8. My knock8 is very low, 1-4 so far, and my knock16 has been between 400-600?
