More flow numbers: L35s vs Vortecs
BillC
Just got my heads back from the porting shop, and thought I'd post some flow numbers. This compares my old heads (heavily worked L35s with 2.02 intake and 1.60 exhaust valves) to my new heads (2.05 intake and 1.6 exhaust valves) both before and after porting (bowl job and intake gasket match). All values are in CFM at 28 inches of water.
Intake
Lift ........ L35 ........ Vortec(before) .. Vortec(after)
.200 ...... 127 ......... 118 ................. 126
.300 ...... 173 ......... 168 ................. 183
.400 ...... 205 ......... 202 ................. 222
.500 ...... 224 ......... 205 ................. 257
.600 ...... 233 ......... 209 ................. 238
.700 ...... 237 ......... 211 ................. 239
Exhaust
.200 ...... 109 ......... 115 ................. 121
.300 ...... 156 ......... 147 ................. 147
.400 ...... 180 ......... 158 ................. 160
.500 ...... 192 ......... 163 ................. 172
.600 ...... 198 ......... 163 ................. 176
.700 ...... 199 ......... 165 ................. 179
The intake flow of the Vortec peaked at .500 lift and dropped off after that. They said it was because the flow was stalling at the bottle-neck where the intake passed the pushrod. Since I'm only planning to run .533 lift (412 cam and 1.6 roller rockers), that shouldn't be a problem.
Buster
Thanks for posting your numbers, now the real question is do we need more intake or exhaust flow. I know nothing about setting up good heads, so I thought I'd ask.
sytyguy
Moderated User
Those are some serious exhaust numbers on the L35s....Who did the port work on them? Who did the Vortecs?
Does anybody have stock L35 numbers (or unported, big valve L35s)?
Thanks for the numbers Bill.
Hood
syclone2910
with flow numbers on the L35's more on the exhaust and a little less on the intake what would be the point of spending the extra money on the vortecs for? Just wondering
CLONE
First they are heavily worked L35's and lightly worked vortec's. Not a great comparison but interesting anyways. Second, the combustion chamber on the vortec's is awesome. The combustion chamber on the L-35's suck in comparison.
syclone2910
i just put a set of worked L35's on my truck. I forgot about the bowl design though. But is it still really worth it?
CLONE
Worth it? Like any other mod, it depends.
jwaller
Evil Genius/SyTy Guru
if you like modern technology and a better design then yes it's worth it. if that doesn't mean much to you then stick with your L35's. :fist: 0X
BillC
The same shop did both sets of heads: Ladd's Porting, Elkridge, MD, 410-799-1763. Since both sets of heads were flowed on the same bench, the numbers should be directly comparable (even though they were done three years apart).
Ladd's could have easily gotten the same, or better, flow numbers out of the Vortecs' exhaust, if I'd felt like paying them for a full port&polish. However, since I'm still using the stock exhaust manifolds, I didn't think it would be worthwhile.
BTW, the L35s are for sale, fairly cheap, if anyone is interested. One head is in great shape, the other has a crack that the machine shop thought could be repaired (but they weren't absolutely sure). You could either try to get the head fixed, or cut it up and use it as a pattern for porting a replacement.
Buster
Yeah if your local dealer sells head gaskets by the case.
