more innercooler coolent
justin949
my friend was telling me that i should convert my winshild washer reservoir into an innercooler reservoir giveing me an extra 3 to 4 quarts i have a new innercoolent pump that flows 3-4 gpm (he said i could put ice in the winshild washer resrvoir. thanks just wanted to know what you think!
GEN3Typhoon
I think your friend has a good idea.. Just not for the windshield solvent bottle.
I think more volume in the system is a must... I don't think that an extra half a gallon is going to make much difference.
I know Jeff Scott messed with this some and had some good results.
ed hess
race or get outta the way
i knew someone many years ago that did the following:
Add a 2nd resevoir and pump to the system. redirect the output to someplace like the glove box or rear of the truck. get some shiny chrome stuff for the end of the lines Now put tangurey in one and tonic in the other resevoir and you will be all set good to go!
ed
i have a 15 gallon tank in the back, pump's back there, 4 smallish motorcycle radiators with fans in teh return line.
my intercooler water output temps basically don't move.
you could use a smaller version in teh ty inside, or maybe mount the tank underneath.
lmk if u need more info.
btw, the w/shield washer tank is way tooo small to do shit, plus the outlets are too small.
