More newbie questions......
SY2767
Just a couple of questions, is there a "trick" to getting #3 spark plug out? And how difficult should it be to move the rod on the stock waste gate ( i am assuming that's what it is with the rod attached to it going from the turbo to the exhaust manifold)?
SY2455
70's Veteran
Re: More newbie questions......
You need to go to Sears and get a 3/8 drive flexible spark plug 5/8 socket part# 0943322.
ZMann
vertically challenged
at sears you can by a swivel spark plug socket that works great.
To adjust the wastegate rod, you have to "carefully" remove the pin and then you can turn the rod longer or make it shorter.
SY2767
:oops:
I didn't know it was adjustable, how do i tell if it needs adjusting? Please help as i am very new to this "turbo" thing...... :oops:
ZMann
Do you have a aftermarket boost gauge? Dont trust the stock one. But stay under 15 psi of boost enless your truck has a 3 bar map sensor and chip. All the information you need is on this site somewhere... you can use the search feature for most questions... We'll try to help you as much as we can. :)
SY2767
I don't have a aftermarket boost gauge yet, i will be getting one this weekend. What do everyone recommend for a stock syclone??
ZMann
Any boost gauge will work. Autometer is what i have. I have my boost line tied into the manifold somewhere... I forget.
ghettosled
SYTY SUPERSTORE
get a short spark pliug socket with a hex head. Break loose with a stubby wrench (usually 3/4") then remove by hand. If in a hurry just break the plug in half by prying on the plug with the socket, then it comes out with a standard socket and wobbly extension.
If you dont break the plug in half, make sure not to loosen too much with the socket still on or it will hit the steering shaft and you wont have enough clearnace to slide it off.
wantingasy
:werd: After about an hour trying to get it out I called my dad and he was all "Well, can you put a wrench on the spark plug socket and turn it loose?" I felt like a dumb A$$. Like 10 seconds and it was out. :oops:
attackdog
I just cut 1/4" off one of my old spark plug sockets to make it shorter. Works good for me.
-Deano
JKsSyclone
Thats how I do it. I think its the easiest way. I even made a wrench for it by cutting a "made in china" wrench to the perfect length. It work great. :tup:
attackdog
What length did you cut the wrench? I am going to give that a shot. Thanks.
-Deano
JKsSyclone
-Deano
I didnt really measure it when I cut it. I just broke out the die-grinder and went after it. :lol: I'll have to look when I get home tonight.
wantingasy
My spark plug snapped under pressure and scared the shit out of me because I thought I cross threaded it or something. :roll:
SY2932
Administrator
Yup, I bought one of those seven years ago:
"Craftsman #43322 ($9.99) 5/8" swivel spark plug socket in action on plug #3."
gjp
another post whore
I get an award for the most plug changes in the first year of ownership. Changed them I think 10 times with another comming soon now that I have alky. I can do them in 10 min. Use the sears socket and use anti-seize on the threads and silicone on the boot.. They also make a sweet 1/4 drive 9/16 short socket for the distributor. It works perfect.
