IF you have run any wiring through the fire wall,for say a boost gauge or f/p gauge or any other accessory that you made holes for, make sure the holes are sealed up good.
on my other truck i had water entry through a loose grommet for my boost gauge on the fire wall...sealed it,no leak
if it were a door seal or something you SHOULD be able to see where the water is running down the jam-
also,i dont know were it is,or if our trucks have it,but the heaterbox/evaporator for the ac must have a drain tube for condinsation that COULD leak into the cab if clogged or kinked...
just a few ideas...hth
T
