Motec questions
AXXE
What kind of experiences has anyone had with Motec? My engine builder sells it and says it is a great system. How does it compare to FAST and Accel Gen VII?
ed hess
race or get outta the way
Dont think anyone in systy land uses it.
like i said let me know and i will hook you up with harry for the gen7.
should have some times within the next week or 2.
I just need to kow i have found all the gremlins that keep popping up latley.
ed
MadPSI
I'm using FAST now and it works well. Way more tweaking ability than I need... Haven't heard anything about Accel. Motec is far-and-away the most advancecd system out there, but it's also way expensive. I'd only go motec if you're expecting to run sub 8s in the quarter, or if you have a show car and are going for the "wow" factor... They do make some neato steering wheels though.
smeagol
Motec has a LOT of options, but is expensive, and nearly every application is done custom. Meaning you better be damn good hands-on, or have some serious $ if you want to use it on a Syty.
So bottom line:
Good, but if you want to use it it will take a lot of money and labor (or just a LOT of money).
For less money and work, with pretty good features, the DFI v7 or FAST are better choices IMO.
ed hess
i'm happy with the gen7. but i dont think you will find anyone here that used both gen7 and fast, possibly some gen6 users that converted to fast.
ed
AXXE
I was at the engine builder's again yesterday. He is still trying to sell me on the Motec. He said it switches to sequential FI and it will control boost. He said I could set it to run low boost off the line until it hooks, then go to full boost. It is expensive - like $2500 installed and tuned. Do the FAST and Gen 7 control boost? I am not trying to set any speed records. I just want something that will make the truck run good and will be somewhat easy to use if I go to injectors larger than 50#.
smeagol
I don't think there is any way to get it installed & tuned for $2500... if so, you'll be lacking on some features.
Motec isn't required to make a truck run decent on injectors larger than 50#. That's mainly in the calibration, it can be done in FAST, DFI v7, stock ECM. Don't let him sell you on the Motec is the best - typically Motec can offer almost anything you want, but you will pay extra for every little feature you'd like to use. There's no doubt in my mind it's a great computer, but do you really need it? If you are on any budget, I say throw that idea out the window.
Motec supplies NO plug n play harness for a syty. To control a launch boost, you'll need to have some sort of low base boost wastegate - ask Ed about this - it's the same for the Innovative controller, AEM whatever. Sequential - you'll need to install some sort of cam sensor. Are you ready for little odds & ends like this to add up?
I would be surprised if he could install & tune a Motec on your truck for less than $4000 complete, to be honest.
ed hess
Like brian just said, i would expect it to be more than 4k installed.
I just looked at part of the wiring diagram on the motec site and yes the motec can do boost control.
fwiw, my setup using the innovative multistage boost controller with the minigate is pretty common in our application and give you all you need for boost control.
You can do a programmable ecu like gen7 without boost controll and save yourself some money.
Rather than listen to just us and the motec salesman, after you have read up a it more let me know and i will get you in touch with harry.
the msbc has a launch mode that allows you to launch at whatever boost you want. it can only go as low as the base spring pressure in your wastegate. a lower rated spring is available for the minigate. however the standard spring is 10 psi.
You probably allready read how i launch with my dfi7.
1 stage
2 hit brake, pump 2x
3 set dual line locks
4 nail gas and let off brake
5 gen7 turns on rev limiter via line lock switch
6 boost controller goes into launch mode via line lock switch
7 truck builds boost to whatever i set msbc to almost instantly via on board boost builder feature of gen7 (dont know if motec has this)
8 let go of line lock button on last amber
the truck then becomes the next best thing to an amusement ride
ed
btw i got interrupted writing this and harry called me. He said with motec your probabaly more like 6k by the time you are done. I think he said the guy you talked to was full of it to tell you 2500.
AXXE
I can see that I have a lot of research to do. I forgot about that base boost and the WG spring, Duh. Ed, let me know how your truck does at the track. Are there harnesses readily available for the Gen 7 and the FAST? Is switching to sequential a big difference in performance? Last question - Is going DFI worth it, or should I just try a custom chip with 84# injectors? Thanks everyone.
ed hess
Tuning is just about done. Ya know i have never in 13 years of owning this truck seen the tach sit totally still at idle. Amazing with 84# injectors.
Even the damn gas gauge aint movin as quickly!!!
I hope to get to the track within the next week or 2.
Dan white racing has an adapter harness for the syty and gen7. He just discovered from my install that he needs to do a modification for the injector harness. except for that its is a failry simple plug in. You do have to make a simple bracket for the manifold temp sensor.
Sequential vz bank to bank? harry is of the opinion it wont make enough difference based on what he has seen so far to justify the expense.
I could have gone with the chip burning and custom tuning route.
I think more users of this bbs do that than fast or gen7 (so far i am the 1st on gen7 here). Gen7 has some features that you can not do in a modified ecm. Granted you could use msd products to come close to some of them. But i prefered a more integrated package. Besides that I simply dont have the room to install any size msd hardware. Heck i still have the A/c in the truck and it works. I think i kept it there as a novelty conversation piece for an 11 second daily driver as i never in 13 years have given it much use. It does aid in defoging the windshield so i keep it.
Start doing some reading. At the begining it can be overwhelming. If you do like i do you dont need to know everything about it if you will have a tuner tune it fo you. But i would think you would do the install yourself. Ya know i dont know if harry does the installs.
I can tell you the help files for gen7 do not give you step by step how to. I beleive this was intentional on accels part to help support their emic's (tuners).
Like i said before i also based my decision on the availablity of local tech talent to help in doing this. i.e harry.
The other night harry is sitting there doing stuff on the laptop and he gives me this look, I just looked at him and said, dont ask me i just build the stuff, i dont tune it. :D
However everything you do need is there if you know what you are doing.
ed
ed hess
oh yeah
absolutely!
Heck i even know the private phone number to instantly reach their top dog tech support person.
In fact they are so responsive i call up and they instantly recognize my voice without me telling them who it is. :D
ed
