motor is dead!
E-Rue
pulled out my #6 plug and its dripping fresh oil.
wish me luck figureing out this mccoy motor and getting it back on the road quickly. i still wanna drive it while its warm. lol
e
Typhoonracer
Old Guard GURU
Eric,
Is that the 2 bolt mains motor that you ran the T-74 on for a while???
I wonder why its not happy........
Steve
Loeryder
Damn Dood that blows big chunks.
So how many miles are on your motor?
Surely doesn't seem right that there is already oil past the rings...
Wish you luck brotha.
TurboManiacal
Typhoonracer said:
Eric,
Steve
Yeah the same motor that's prolly got 5000 miles on it since installation 2 years ago.
E-Rue
might have had something to do with me going a tad lean with a big cam, a PT74 and 20PSI!
e
TurboTony
Have you leaked it down or done a compression test yet?
Might be as simple as an intake leaking. You have those double gasket deals on the intake right?
Just trying to be optomistic :wink:
Tony
Jimmy
Banned
Tony
I'm 99% sure that he's running worked L35's.
jwaller
Evil Genius/SyTy Guru
E prolly forgot that when you change the oil your not supposed to "fill it up" (ie running out of the valve cover) those damn ghetto booty lovers always love their oil's
sytydvr
Do a compression check if its low check your valve for proper adjusment they might be too tight.... if your compression is good your plug or spark plug wire is bad...
It cant be an intake because not much oil can go through there.
if lets say you have low compression and your valves have been properly adjusted you most likely have broken rings and/or cracked piston
I hope its just a fouled plug
good luck E
E-Rue
you guys are missin the point..... there is so much oil on the plug, it looks like i just dipped it in an oil pan. lol at the very least id have to take the head off, and to be honest if im gonna go that far, id rather remove the motor and do all the things i wish i had done to start with. i have a short wish list, and i hope to have it fixed and running again next month.
ill let ya know what we find when i get it out of the truck.
e
