motor is finally back in!
fiveoh
Enforcing traffic laws
I can finally see daylight at the end, the new motor is now bolted to the mounts and bolted to the trans w/teh exception of the top left bolt :evil:
any way i called it a day at about 5 pm because i couldnt think properly.
i know sometimes it is better to start fresh than keep on going and f-ing something up.
but anyways it should be driving in about a week or two. weather permitting :rock: :rock: :rock: :rock:
i will post thumbnails of everything and the build sheet when it totally finished,, and to think i started this with a budget in mind :2cents: yeah right at least 4,500 later. :tup:
overboost
Good to here your almost done. :tup: I just got my engine out today. Did you build your engine or did you have some one else build it? I am going to do it my self to learn and to save some :2cents: . What is your build and what are you shooting for 11's, 12's?
PPI Typhoon
DIY Madman
Re: motor is finally back in!
I'm jealous. I'm still in the very beginning stages (gathering parts)
Can't wait to see your pics and buildsheet. :tup: :rock:
fiveoh
i did not do the rebuild, i dont have the machine shop available for what i needed done to my motor.
my build is a basic .030 over with forged pistons....l35 heads. 412 cam. comp magnum 1.52 roller rockers...yada yada yada..lol my goals were just a reliable veh. i wasnt looking to improve e.t at all but while i was doing the rebuild i could not resist :roll: ...as stated i have no goals for say a 12 sec car, ill be happy with 13's
good luck with your truck
mjaugus
Good Luck,sounds like your almost there.Pulled mine last dec. and hope to reload soon.Thanksgiving or Christmass,whenever my kid can get home from school to help.Everything was so clear when it came out,but now it,s just a distant memory.Anything you would have done different as far as the install went.Hope it gets warmer.
fiveoh
the only thing i would have done different is mark all of the bolts and keep them seperated, i knew that i should have done that, but was jsut tossing them in a box , not having them marked jsut makes things a bit slower going back in. the install went very smooth...it only took about an hour or so(probably not even that long) to get the motor bolted to the mounts and to get 2 trans bolts started.
SY2932
Administrator
Have "fun" getting that topmost bellhousing on the passenger side back in. That's the bolt that doesn't have a flange on it because uses the bracket for the trans fill tube as a washer. There is also a clip that holds the wiring harness that uses that bolt too. Lotsa fun trying to thread that bolt through two brackets in a very confined space. That's the one I dread the most... Congrats on having a functional syty soon 8) ! You are well on your way to obtaining the goal for your truck.
