Re: Motor mount bolts.
Other than dropping the diff, I've tried everything. I don't know how you'd get a stubby wrench all the way up there since I can't even fit a hand between the bottom of the frame mount and the top of the diff even with the diff hose removed.
All of the other bolts so far have been really easy to get out. I've got the lower I/C out, took off the crossover, and removed the steering shaft to get access to everything so far. For lifting the motor, I've found it's easiest to jack it up using the inspection cover at the front of the trans.
There's barely any room to see what you're doing too. The only way I can even see the nut on the backside is to lay on my back right under the front diff and look up between the diff and the frame rail. I can see it, but can't get a socket between the diff and the frame because it's too tight. Of course, trying to do this with one set of hands is even harder....
Back to work.
