Ok, Im installing Energy suspension mounts & JS frampads in my blazer. Both OEM drivers side & passenger side are broken. I got the drivers side in, had a little trouble getting the bolt through the mount & the pad, But i got it.
Went to do the passenger side & ran into a little problem while trying to put the passenger side in. The motor mount wont line up with the framepad. Not that the bolt holes wont line up, i cant get the framepad to go inside mount mout part where the two would slide together. When I lower the motor, the forward part of the mount sits on the top edge of the pad, little more than 1/8" from the 2 peices sliding together. There is extra room on the back side between the mount & the pad. I've tried loosening the pads & mount to try and line them up after they slide together but it didnt work. Also tried prying to motor forward but cant move it. ANyone have any ideas???
Please HeLP!!!!!!! asap
thanks
thanks
