Well i recently bought a non running Ty that ws a theft recovery and yesterday i took ti around the block for the first time, and noticed it had a broken driver side motor mount and the steering is very loose, the idler and pitman are are completly wasted.
Well thats easy enough to fix, but iwas wondering about the motor mounts, it seem ive heard of a few folks melting the poly mounts, so i was thinking about just going with the Solid moun ts, but wanted to know if anyody sells a soild trans mount for our trucks?
I read that if you dont run a solid trans mount with your solid motor mounts you will crack the trans case?? Has anybody tried this? Maybe use the poly trans mount and soild motor mounts??????????
I know this is one of thise PITA jobs and i only want to do it once.
TIA.
TIA.
