MyGMCSyclone
I all,
I will be comming into enought cash to fix my SY and need some suggestions on what are the correct parts to get to rebuild my motor. I would like to keep it fairly stock. I will be using the stock heads and turbo. The previous owner did not take care of this maintenance wise. So to be safe I’ll have it bored. I have been looking at the RPM site and came up with a list of parts below. Am I heading in the right direction if not please feel free to correct me. I did find a few of the parts below cheaper and will get thoes to save some cash.
Crankshaft - Stock Core 12-139-100
Connecting Rods - Eagle H Beam 5.7"(SyTy) 12-123-CRS57006
Pistons - SRP 4.030 (8.5:1) 12-177-139632
Piston Ring Set - JE Pro Series (4.030) 12-144-4030R
Bearing - Cam 12-114-3551
Bearing - Main (.010) 12-130-0909H10
Bearing - Rod (.010) 12-130-7085CH10
Bolt - ARP Main Studs (2 bolt main) 12-104-5401
Bolt -ARP Head Bolts (12 point) 12-104-3701
Gasket - Engine Rebuild - Head Set 12-114-5855HS
Gasket - Engine Rebuild - Shortblock Set 12-114-5744
Camshaft - COMP 09-412-8 12-117-9412
Valvetrain - Lifters - COMP Cams High Energy 12-117-0850
Valvetrain - Pushrods - COMP High Energy 12-117-7808
Roller Rockers 1.6 Full Stainless Self Aligning 13-100-235005
Valvetrain - Timing Chain - Double Roller 12-125-7801
Valvetrain - Timing Chain Cover 13-100-6300
Valvetrain - Timing Pointer - Billet 13-100-3625
Oil Pump - High Output Kit 12-152-0M55A
Flexplate - RPM SFI 13-100-5003
Damper - Pioneer SFI 12-162-72001
Also if I remove the front clip will the tranny and t-case come out in one piece? I’ve taken the tranny out of this twice (the first Waller rebuild the reverse didn’t work) not fun.:tdown: The tranny has to be rebuilt again anyway because it is slipping very very bad. I’m a little upset about this as this Waller tranny should have lasted longer than 4000 miles and 8 months and didn’t even beat on it.
Thanks for any advice. :tup:
Russ
Russ
