THis is just a FYI kinda thing. The top two bolts that connect the bell housing to the engine block can be installed easily through the top with the upper intake manifold removed and you don't have to remove the trans. crossmember. The trick is use a piece of thread and tie a slipknot in it to hold the bolt and just hang it with one hand and push it through the hole with the other. Then just pull the thread until it breaks off the bolt and tighten with a wrench. After dropping and losing two bolts in the engine bay and 30minutes wasted, I decided to figure out a plan that works better. The thread trick only took me like 2 minutes.
HTH's anyone,
Jordan
HTH's anyone,
Jordan
