Mounting Battery in the Back... Wiring help
ShuggsRR
I know how and where to put the battery box in the trunk of the Ty. Where do i run the wire? I bought the Summit box and its a 1 gauge wire that came with grommets and fastners and all. Where do I run the wire to? A distribution block?
Also, do you guys run the wires down your frame rail? or on the body? If you run it down the frame rail, how did you drill the holes?
Thanks for the help, I guess I should have asked this before I got under the truck. ack.
I did find one thread on it, but everyone seems to have thier own opinions and Im not sure how to find the starter wires or how to run a 1 gauage wire to my alternator.
http://www.syty.net/forums/showthread.php?t=51970
4C FED
Absolutum Dominium
Re: Mounting Battery in the Back... Wiring help
You don't need a 1 ga. wire to the alt., maybe a 4 ga. at the most.
Run your 1 ga. to the distribution point and the starter. Then the 4 ga. to the distribution point or back to the battery if you'd like.
I used those Moroso jumper terminals as a distribution point. You could also use the thru-panel connectors the same way and these let you attach more wires. You'll have to locate them somewhere convenient and safe.
As for running the cable, I ran mine along the frame rail. I used some of those nylon cable clamps and drilled holes in frame to mount.
ShuggsRR
Thanks...
Everyone makes it sound so easy to run a cable to the starter. How? I have looked all over.... What do I do, get underneath and drop the starter to get to it?
Couldt I just attach the factory starter wire to the factory dist block on the firewall, and then run my new battery cable to the dist block on the firewall as well? Wouldnt that do it?
Flyin Ryan
hated cuz he drives fords
My suggestion is to run your 1g wire up to the engine bay however you prefer.. I'd prob go with outside of the frame so you don't have to worry about abrasion shredding up and exposing your cable.
Purchase a remote battery junction terminal like this http://www.stanford.edu/~sunid/battery/images/BreakersWithCover.JPG from napa or whoever.
mount it wherever you prefer, run your 1g cable to it, then attach your starter and alt cables to the other lug. 4g cable would be fine with your stock or 140 amp alt
In that diagram on that link, I ran 2 gauge to everything... kinda sucked doing because it's stiffer cable and made it interesting trying to bend and form it to the starter :)
ShuggsRR
Wow... that sounds like a great idea. Just use my factory cable and attach them to my junction terminal. Then run my 1g from the back and I should be golden.
Hmm Ill try that route. Might save my sanity.
MadPSI
I relocated my battery to the bed of my Sy a couple weeks ago. I used 0ga wire and standard copper terminals which I got from NAPA and soldered on via a torch. I ran the positive along the frame rail to the starter, and then ran a separate 4ga from the starter to the alt. I tapped a hole in the frame just underneath the battery box and bolted the negative lead there. It worked out very well, and looks clean.
The only place that is of any concern is the area where the downpipe comes close to the frame near the starter. Using a cable strap to keep the wire away from the DP is simple enough. It's very easy to run the wires if your wheel wells are out.
This is probably way beyond overkill, but it's the only way I like to do things...
ShuggsRR
Why is there a nee to run a larger wire to the alternator? Is the factor wire not good enough? Mine has worked fine for 16 years and seems to be fine still.
Big Mike
Remember to include a battery cut off switch that actually cuts the power and turns the truck off when activated. Many do not do this right. If it does not turn the truck off it will not be NHRA legal also no plastic switches allowed.
ShuggsRR
Why would I want a cut off switch?
Loeryder
With a battery relocate, if there is no shut off accessible OUTSIDE the vehicle you will not pass tech at the tracks.
This also means that any thief can walk up and disconnect your battery.
I have seen ones that took a key to shut off that you can remove when the vehicle is parked, but dont remember who made it.
This is the only thing stopping me from relocating mine.
sy2675
He Saved the Pimp'n Game!
i agree if you run it at a strict track, a stupid rule in my opinion, there isnt a cut off for a front mounted battery, how would you KILL the truck if you couldnt open the hood?
I have had no issues at the tracks i go to, but im sure that will change.
as for wire size, mine is all 2 gauge or 0 gauge, overkill is always better than too small of wire.
some sort of heat sheild would be recommended by me if anywhere near the downpipe, its cheap enough and better than welding a 4-2-0 gauge wire to your down pipe.
ShuggsRR
Gotcha. Didnt know about the track rule. I have never been to the track and dont plan to take the Ty to the track anytime soon. Might be a good plan though.
thanks!
ShuggsRR
So to wire it to the strater, how did you get to it? Drop the starter down from below the truck and then do it? Do I need to remove the trans flywheel cover?
I think the idea is that with that bat under the hood the crash crew can use cable cutters to disconnect the bat. Assuming, of course, they can get the hood open. NHRA wants a manual disconnect for any "relocated" battery. It must be on the positive circuit and kill the engine when turned off.
As mentioned, because of the switch requirement, among other things, I haven't relocated my bat either. Maybe next winter. Find and old S10 gate and cut the hole for the switch control in that. Then swap gates on race day. :roll:
