mounting cruise after abs delete
blk00z28
Forced to by choice
I was wondering where you guys mounted it after you deleted your abs. That is for those of you who still kept it. Can you post some pictures.
I'm not running inner fenders so it poses a bit of a problem. I will put them back in at some point, but I don't want anything attached to them.(for a cleaner look)
Opinions?
ty166
Re: mounting cruise after abs delete
i could be wrong but i thought renz was making a bracket for mounting cruise after abs delete.
blk00z28
Forced to by choice
Lol, the only thing I'm deleting is the abs, I'm keeping everything else because its a true street truck.
MikeRenz
not stock
the brackets i make, so far anyway, are just stock replacement which still mount to the inner fender. Does the CC cabling reach up to the fender where the washer fluid or abs unit was? If so you could easily make something that bolts up there, or i could make something for you if you don't have the means.
Loeryder
I might get something like this done as well.
There are times I'd like to run with both front fenders out.
Its a street truck so its got cruise and AC still.
turbodog
I just mounted the cruise bracket directly to the fenderwell. I forget if I had to drill a hole, but I think I just used an existing one. Works fine.
blk00z28
Forced to by choice
I dont know if it will reach the side fender as I'm still waiting for Hood to make another batch of abs delete kits.
My only problem with this is I dont know if it will reach being I'm not using the stock intake(s). I'm doing carb style. So it might be pushing it to far away at that point. And I wont know until everythings back in the truck. And not only that, I'll be running headers so I dont want to hang something off the motor just yet and then have to change it because it hits them.
turbodog, you have any pics?
