Re: MPFI Conversion or Sy/TY Intake Swap?
Just curious do you already have the stroker Crank ?? If not the only stroker you can get is billet and i have one sitting on my shelf that i paid $3300 for.
If your looking for 280hp (same as i am with my black gt) there are other options.
you can see a post the Mike Hot Rod v6 did on the GT board
try to make it quick and painless. I'm restoring my GT and the
engine/transmission are next on my list of things to yank out and get
fixed. I was wondering how to put the max horses out and what to do.
Basically, if I took it to the machine shop, what would I tell them to
do? Cam? Pistons? Heads? Trans Servos? Right now, price is really a
difficulty as long as it's not too outrageous. I just want to know how
big I should have them bore "this" out or what brand of "that" I should
have them put on. Fun, creative stuff.... that's costs a lot of
money... oh well, worth it I guess. Oh, and I'm not exactly engine
savvy, so a lot of terms you'll have to tell me in black and white.
Thanks
~Chris~
Well if the block doesn't need bored,then i would keep it standard bore, you ll get better cooling that way, but if its needed then a .030 overbore should be fine. As far as heads go you can have your stock L35 heads ported and polished for better flow, or get a set of the 96+ vortec heads, you will have to have the intake welded to cover the ports on the head, because they are a rasied port design, and you have to have the heads redrilled for the early intake manifold bolt pattern, but the gains are well worth the increase in power. As far as a cam, well you have a few choices and it really depends on what you do with the heads.
I have an extrude honed upper and lower CPI intake that was on a truck that had a stock bottom end, reground stock cam (.550 lift) and extrude honed L35 heads and with a 100 shot of Nitrous it went 12.20 and hit the rev limiter at the 1000' mark, so you can see the intake can make and support some serious power, i can send pics if the intake if your interested, then all you would have to do is have your stock heads ported for more flow and the intake in a direct bolt on for your stocker.
Or if you wanted to go with the 96+ heads i also have a CPI lower intake that has been welded up already and will work with the 96+ heads no problem, all you would need to do is get a set of the newer heads, and have the bolt pattern redrilled and tapped in the heads, not a big deal at all, if you do some research on SyTy.net there are lots of posts about having it done, most will be for the stock SyTy intake but the job is the same for either one.
I can send pics of it if your interested in either one, and youll notice some nice gains in power for your GT.
Good luck
Mike
