Did you ever figure this out? I just did a complete tune-up and installed the 6A with MSD coil. If the tan/black wire is disconnected it wont idle when i get close to 0*TDC, i feathered the throttle and got it as close as possible to 0. Then with the tan/black wire reconnected it reads something like 25 degrees advanced. I know its 25 because i have a nice digital timing gun. But it idles and runs great, so i cant complain. Just curious about that "wont idle with the EST bypass disconnected" thing.0-60N4 said:I recently installed the MSD 6A and Blaster SS coil. Runs and idles fine. But if I disconnect the EST bypass connector to check the base timing, the engine will not idle. I have to rev it above 1200 rpm to keep it running. Any lower and it abruply dies. Anyone else seen this?
