MSD 6al with stock coil
Anybody do this? Reinstalled my MSD box today leaving the stock coil there. Motor fired but I didn't test drive it. Will do that tomorrow. Not sure my MSD coil is even good so didn't want to change it if I didn't have to.
Thanks.
SY2455
70's Veteran
Re: MSD 6al with stock coil
I have been that way for a long time now after the MSD 6 used with the MSD coil burned holes in the dist cap at all 6 spark plug towers.
jimmyz79
Re-Member
This happened to me on a different GM, so I'm gunshy about putting an MSD unit on a TY.
Never had a problem with MSD coil & wires without the unit though...
Throws
What's the advantage of a a 6A box on a stock ignition? At what point does a 6A become more of a necessity than a nicety?
-P
First, thanks all. Nice to know others have been doing this.
I suspect cross fire would cause this. Scroll down to page 13 for a possible solution to this:
http://www.scribd.com/doc/92106499/MSD-IGNITION-Wiring-Diagrams-and-Tech-Notes
Also if you look at page 14 and test the phasing I think you'll find out our dist is Not phased correctly. At least I did. I've hesitated posting this but here ya go: I've made an custom rotor using the "T" shaped tip from a Ford rotor adapted to our rotor to correct this. Anyhow use an old cap and drill holes around one of the terminals like it says so you can see the phasing.
I did this because I was seeing strange marks inside the cap between terminals which led me to believe that phasing might be an issue. Also the location of the burn marks on both the rotor and the cap terminals indicated that the rotor was not inline with the cap terminals when the coil fired.
Like I said I didn't want to open a can of worms with this phasing thing but what the heck.:roll: Our ignitions work under very high load because of the motor being turbocharged so I figured every little bit helps.
No I do NOT have any pics . I'll get some today but may not be able to post them until tomorrow.
SY2455
70's Veteran
Don,
On mine the holes were right under the terminals, inline with the brass terminal so I think the phasing was correct. Because of this I was thinking that the spark was too hot with the MSD coil. It only took 1 month for the burn though with a new cap and rotor with new MSD plugwires. That was a very interesting reading :tup:.
SY2455
70's Veteran
-P
On my truck the engine runs alot better with a gain in mpg.
Hard to tell but here's a photo. This was taken with the reluctor directly aligned with the stator (not sure if that's the correct term). In the pic the rotor is just past the dist terminal. To me it should be directly aligned.
Here's where I'm ignorant. Since there is no "advance" mechanism IN the dist, it being all controlled by the ECM, advancing the timing would bring the rotor more inline with the terminal in the cap would it not???.
Anyway, good, bad, or otherwise, this is what I was trying to explain earlier with respect to dist phasing.
https://dl.dropbox.com/u/86797850/Dist phasing.jpg
Throws
So, "phasing" the rotor to the terminal would allow that spark the full time on that terminal as opposed to leaving before it full completes?
-P
Sort of. The goal is to prevent cross fireing (jumping to an adjacent terminal) or to ground. Remember, electricity always takes the path of least resistance. There is a lot of resitance at the spark plug that's trying to fire because of the high cylinder pressure so if the spark can find another path it'll take it.
So IOW it's little more than the "every little bit helps" theory.
Ya, that out of phase dist from the rebuilder was really weird. Actually took me quite awhile to figure that out. What you see here is nothing like what it was back then. I was amazed the motor even ran.
I still run that Ford rotor adaption, even though, compared to last time, it's only out a little bit. If nothing else it makes me feel better...:rotf:
