MSD 8367 O-rings
jwaller
Evil Genius/SyTy Guru
use them. but make sure when you install it that you lube the rings so that they dont get caught on the block and pull off.
some use them some dont. but if you want a bit more oil press then use them.
Matthew Little
msd
msd
I called MSD about this dist today and they told me it wouldn't work on these trucks, so wtf. I have seen guys talking about it, so does it work and is it a bolt in replacement? Thanks for any help.
skata
Re: msd
Re: msd
the msd 8367 is a direct replacement.
you should use the o-rings too, unless you cant get the distributor in with them.
skata
Tommyquest said:
do you use the washer (same diameter as the collar) that came with it too?
are you referring to the round paper gasket? if so, then yes use it.
there is supposed to be a round gasket between the distributor collar and manifold to prevent oil seeping out.
Tommyquest
The Member's Member
skata said:
are you referring to the round paper gasket? if so, then yes use it. there is supposed to be a round gasket between the distributor collar and manifold to prevent oil seeping out.
Yes that's the one. I figured it was a gasket. Seemed pretty thin to be a spacer. Thanks for the info.
Matthew Little
msd
msd
Thanks Tommyquest, Let me know how yours turns out, I am getting ready to get one. Tired of changing cap and rotors(msd blaster coil)
