MSD billet dizzy, mods/setup for EFI
brock1949
Its alive!!!
So unless someone has a cheaper crank trigger option then RPM's which i may still just do to save cutting up 330 dollar dizzy i think i'm going to convert it to crank trigger.
After talking to BS3 and MSD it sounds like i need to cut 5 of the 6 paddles off of the reluctor setup then point that #1 to the sensor and install it with 45-50 degree's advance. The issue si then my rotors pointing at the wrong cylinder so i need to adjust it back which what i was told is that a adjustable rotor won't go far enough back to make it work right so the better options to press roll pin out of 6 paddle reluctor (that gets 5 cut off) drill and tap it for set screws and adjust the reluctor spacing back to where the rotor is lined up to the min amout of timing i would want to run.
Do i setup the rotor so its lined up with the min amount of timing or make it line up closest to WOT running 20-30 degree's advance so i'm not loosing power from spark jumping father..
Thanks!
brock1949
Its alive!!!
Re: MSD billet dizzy, mods/setup for EFI
ok just so i don't throw everyone off or someone searching later, most of what i wrote which was a hybrid of what MSD and BS3 told me is wrong lol. Thank god i didn't cut before calling John back at BS3.
All i need to do it install MSD dist at 45-50 with #1 paddle lined up and then put an adjustable rotor on and turn it back the max which is 10 degrees but 20 degrees crank timing and i'm good to go.
Neelsonwheels
If I remember correctley there is a how to video on youtube for exacley this.
I'll look for it and try to post it.
Aeroking
e.i.
instead of cutting up the MSD, can you find a ProComp billet dist to cut up?
edit:
theres one on ebay right now for $109
