Decided to install an MSD Blaster coil today, part # 8226, direct replacement for the stocker. Started and ran fine in the garage. One test drive later, pssfft! misses real bad at anything above part throttle, forget about boost.
What gives? Right now I'm back on the stock coil and it runs like it did before which was OK except; see below.
The reason, in case you're wondering, is that I'm dealing with considerable miss at high RPM WOT with my alky setup. Ultimate set to T1-22 for now. Thinking I was getting coil breakdown under high load I changed the coil. Actually in touch with Nolan on the alky issue, might change the chip ect, so this post is about the coil only but comments welcome.
Also FYI: wires are new Taylor's, cap/rotor new NAPA (which I haven't looked at yet, sorry), and NGK UR5 plugs less than a year old gaped to .028.
Thoughts??
TIA
Thoughts??
TIA
