Mushy Brakes... HELP!
Hey everybody,
My truck has been suffering from mushy brakes. Everytime i fix something i feel like "oh i've finally found the problem yipee", but like anybody knows with sy/ty's the solution usually lasts as long as a tank of gas. I had mushy brakes, then by chance blew a brake like. And thinking that was the problem, replaced it, flushed the fluid and it was beautiful for like a week, now they're mushy again. Here are the things i've tried thus far to remedy the situation:
New Brake master cylinder (from my 95s10)
New line under the truck (the one that blew)
and flushed old brake fluid out of the system
Bled the brakes continuosly
can anybody think of anything else, or has somebody else had a problem like this? please respond if you've had anytghing similar to this. thanks in advance!
Eric
James Thomas
"NO CLASS"
Re: Mushy Brakes... HELP!
The bleeding proceedure is very specific if you still have the ABS. You need to follow the shop manual steps closely to make sure all air is expelled.
________
James
Mushy usually means you have or are getting air in the systems. I would double check all your connections, also a bad caliper or wheel cylinder can be you leaking source. Ususally if something leaks it shuld show signs of brake fluid. If you doing just doing brake work the ABS is a straight through system. If you have air in the brake system (and the air is physically in the ABS) and then activate the abs then you have to bleed teh ABS (which is a far more complex procedure.
Flyin Ryan
hated cuz he drives fords
Check both rear drums for leaky cylinders.. you should be able to see if there leaking without taking them apart. If not then my vote goes to air in the ABS module.. Mine breaks went to shit out of no where as well.. it turned out to be the abs module but I eventually started receiving codes.
Captain Morgan
Moderated User
nothing is leaking in the system. no signs at the rear cylinders and the master cylinder never loses fluid, the brakes just get soft.
Syclone#1992
SyTy.net Moderator
Does it have ABS?
Syclone#1992 said:
Does it have ABS?
I would remove that next if you positive that nothing is leaking. I read that the ABS has an o-ring that leak and blow out.
Syclone#1992
SyTy.net Moderator
Yeah, I replaced the ABS on mine because of this issue. Everyone on here told me it was the master cylinder, but it ended up being the ABS, which sucked because it was really big money, wish it was the master cylinder!
mandingo
She's an Alcoholic
ABS in = mushy brakes, no launch hold, ugly in engine bay
ABS out = firm brakes, good launch hold, clean look in egine bay :2cents:
Mike Hood (sytyguy) has them for sale 30 shipped, great deal, easy to do
MIGHTYMOUSE
Turbo F body guy
what is the specific abs bleed procedure? and any pics of the guy aboves delete kit?
well if it is the abs then i'll look into a delete, i've driven trucks with no ABS and its no big deal if you're not being stupid. I am very certain there are no leaks in the system, i'm not losing any fluid, i'm going to look up the bleeding procedure for the ABS and give that a try, if that doesn't work then i might just have to take out the damn thing or buy morgans when he decides to rip his truck apart : )
