my first datamaster file and HELP
Re: my first datamaster file and HELP
Well it loks you dont have any output on the alt, its going from 3 volts to t and then up to 11 and back down again for one, and that is at idle but it says 71 MPH. And it looks to be very rich, going to need more data, but something isnt right thats for sure.
Good luck with it.
93 TY 2185
vortecfiero said:
I have an "extremely low on power" situation
i recorded the engine idleing and then holding it at about 1200 where it gets really rough
http://www.msnusers.com/vortecstuff/Documents/idle.uni
any ideas ?
thanks
craig
Looks like your Knock Sensor circuit isn't working. The ECM will pull timing if it thinks the Sensor is bad or disconnected. Here's some troubleshooting information from the manual.
HTH
93 TY 2185
Give me a run down of all the ECM and motor modifications.
Stock 2 bar?, Are you running an intercooler?
vortecfiero
95/95 L35 block (was a CPI)
260 ftlbs @ 3500
200 hp @ 4500
5 speed V6 fiero transmission 3.55 diff
3000 rpm = 70mph
5500 rpm = `130 mph (the cpi ecm would let me go that high with the speed buffer wire disconnected)
data master
stock ecm and bbzb chip
Syclone intake, sensors, fuel rail etc
2 bar map
dual knock sens for CPI (will probably change)
cleaned and flow tested stock injectors - red tops
SyTy fuel pump (for now)
no intercooler yet (for now)
wastegate set at 5lbs +- (for now)
schedule 40 tubing exhaust manifolds
wrapped with painted header wrap
18 to 21 inch long primarys @ 1.5" dia
merge collectors to 2" collector
merge collector for turbo flange
boost control not used other than a waste gate
huge T03 turbine off a GMC pickup (strangest size - 5 bolt pattern)
T04B H3 compressor
2.5" dia tubing from compressor to stock throttlebody
small Audi BOV
ambient air was about 70 deg
full 5 lbs at 2500 rpm any gear except 1st
vaccum at idle is 20 hg
at cruise its 10 to 15 hg
I have ready to install
moates adapter (stock cpi chip for the knock sens profile but i may switch to a stock knock sens)
50lb injectors
3 bar map
a modified syclone IC or a huge speerco a/w IC
my goal is to run about 10 lbs of boost safely
thanks
craig
skwayb
NWSTP
This could be a source of the problem if you have both Knock sensors hooked up. I don't beleive the 749 ecm can handle more than 1 knock sensor. If you have both hooked up to the same connection then it could be overloading the circuit and pull lots of timing. But I didn't really see that in both of your datamaster file... 2 degrees of KR isn't bad. The dual knock sensor is something to look at.
I did notice you were never getting full boost. Your Target boost would be 13.8 psi and you would be in the 6-8 psi range. You might need to play with your waste gate some. I would go 3 bar until you have this setup running properly. That would just introduce another variable to the equation.
vortecfiero
regular features
and a dyno !
i realize this isnt too accurate but still lol its FUN
I have the boost solenoid disconnected and letting the waste gate do its thing because my compression is around 9:1. I have the WG rod tight which is why it is holding more than the set
5 lbs of boost.. although my boost gage never goes over 5lbs
and with no intercooler yet I wanted to play it safe
the ecm sees the dual knock sens set up as one knock sens as they are connected
in parallel and are preset to have the correct resistance this way
I agree that this set up may be too sensitive but keeping in mind that I will be using
A moats adapter with the CPI chip for the Knock sens filters… I decided to leave it for now.
Thanks for your comments J
