my new motor build,will headers help ?
cloneman315
ok just a few quick opinions,since last week my stock pte52 sy motor took out two main bearings and it is off to machine shop now,so my ?is do u guys think i should put headers on it or save the money for a trans,my new build is srp pistons 30, over eagle rods,4 bolt caps l35s stock valves, a mild cam im not sure on the specs of the cam the builder had the cam card,,je rings ,1.5 roller rockers.
scotts4
ADDICTED
Re: my new motor build,will headers help ?
i like headers but nolan ran 10s with his manifolds so if your tranny is stock i would spend the money there .
Syclone#1992
SyTy.net Moderator
Hmmmmm....I would say, if the tranny is still stock and you are running high elevens with 20+ PSI, you should save for a trans and get the headers! Seems as though it is only a matter of time, especially if it is stock and running those times.
cloneman315
yeah the 11.85 was last years time the night it blew up it had the new mccoy fmic on it it seemed like it was making way more power and then boom,
cloneman315
oh also had phills new chip in it it was mean for 2 runs lol so im guessing this new motor build with his new burn is gonna be even more awesome but should i put headers on to get the last edge and then the trans over the winter maybe?I think by the bearing the old motor didnt get oil for some reason it was full 2 oil pump etc maybe
scotts4
ADDICTED
i did my last motor with the stock tranny hoping to get the summer out of it and it lasted about 3 weeks
Timbo
SyTy Stalker
I would save for the transmission first. If you buy the headers and your trans goes, you're screwed until you can afford to get it fixed.
cloneman315
the only thing is the motor is out of the truck now i duuno decisions
Timbo
SyTy Stalker
Headers aren't really a must-have thing. Like Scott mentioned, there have been trucks well into the 10s on stock manifolds. I'm sure it wouldn't be TOO much work to install them while the motor is in the truck if you buy them later on.
100in6
100in6
unless you ride is pretty heavily modified i think there a lot of things for the money that will help you more than headers.
les
cloneman315
im thinking of going with vortechs ,and turbo times build in oct so i figured i would need em just easy that the motors out
