Well i guess i will use this thread to update my progress and pics of my vortec head and custom intake and custom air/air IC setup that will be going on the truck over the next several months.
I started out with a set of 2004 vortec heads and bought some Manley race flow stainless valves in 2.055 intake and 1.60 exhaust, a comp 422 cam, comp 987 dual sprngs and matching steel retainers and locks, magnun stock length pushrods, and the billet timing chain set. Well i dropped off the heads at the machine shop last week to have them flowed, a new valve job and spring seat enlarged for the new valves and springs, and have the stock guides machined down to give me clearence for up to .600 lift. well the shop had some stock valves 1.94/1.50 laying around and we used those for the baseline flow test.
@.600 lift the heads baslined at 219 intake and 155 exhaust. Not al that great, but a good place to start and much better than the stock SyTy heads out of the box.
Well thats really all the info i have for the time being. Its going to be a few weeks before i get them back as they are pretty busy this time of year. Im also haveing an economy port job, which basically opens up and blends the bowl area for the larger valves, and will gasket match the intake and exhaust, and then once i get them back im going to do alittle more port work myself to open the intake and exhaust runners alittle more.
Once i get them back ill post some pics of them, and also the after flow numbers. Im hoping to atleast get them in the 260-270 range, the guy at the shop said that after flowing them, he can see alot of areas where we are going to pick up alot of flow and smooth out the air flow as well.
Once my new intake gets here and a few other parts, ill be posting them up as well.
stay tuned.
stay tuned.
