they make teal duct tape just a FYI
Tried it a couple time, my word of caution would be to be careful.
I like it. How many people of you known about that have run this setup? I personally have never seen it done but I am super interested to see how it works. Were you able to record your previous temps, power, e.t's prior to the modification? I will follow this closely....way to think outside the box!!
Good Luck, Nick
You have to be careful i had a intercooler and meth tuned to perfection. My alky hiccuped and i instantly blew the head gasket and cracked the head. And i had a intercooler for a cushion. Test your meth before every woopin you give her!!!
None that I know of, I did with the RPM A2A and it was really high. Started at 68 Deg. and by the end of the 1/4 there were up to 131 deg. I will keep everone posted. I might even put A 20 hp N2o through it to cool the charge. We will see.
I suspect if you try a different intercooler core you might have different results. I personally have not seen great results with that setup you had, just not enough core area in the air stream. What is in the air stream is mostly a lower end tank.
