My rear finally let go!
autoaddictions
Last November was the last time i had the new combination out to test and tune. I only mad 3 passes and the rear started to make popping sounds. Ive been very busy moving my business and haven't had time to play much. However the NASTE meet is sneaking up so i figured i address some issues.
First on the list !!My upper inter cooler pipe. It was recycled from RMP and i needed it to run a different way it was cooking on the turbo. Also meth injection needed to be set up with duel squirters. Heres what i cam up with.
By fdeninno
By fdeninno
As far as the rear i bought a 8.5" rear from an impala ss and i have every intention of chopping it up to fit in the Typhoon. In the mean time i have installing a new posi for the7.5:
Heres some pics of the carnage.
By fdeninno
By fdeninno
By fdeninno
By fdeninno
solidrockperformance
NO !!! back back !!!
Re: My rear finally let go!
MAN !!! Thats a nice clean set-up!!!! Totally digging all the braided line!! The Impala ss rear should hold for you !!! nice work on engine bay man, really like the dual gussets for the injection. Its almost like a boss on an intake or tapping your own holes on an intake. :tup:
Neelsonwheels
Nice job! Real clean. What size nozzles are you going to run?
What size did you run when you ran a single?:tup:
Injected1
Love your truck. Did you weld in threaded bungs for your meth squirters or just 3/8 aluminum rod that you drilled out and tapped. Regaurdless....really sweet setup, you are very talented. Good luck with the 8.5. We need a build thread on it.
autoaddictions
Afraid i cant take all the credit. MPE aka Keith Mease did the welding. The meth bungs are threaded so you can screw the size nozzle you want on on the inside of the pipe the outside has a -4 fitting screwed into that. the injectors are directly facing the throttle plates.
I dont really need the meth anymore since we built a much larger intercooler. However eventually id like to run pump and meth into the 9s on this combination before i switch out for the bowtie build waiting on the stand.
heres a pic of that.
By fdeninno
sharkbait
so the sheetmetal upper intake is the same truck as the pic of the stock upper with the meth injectors? im confused.
Injected1
same valve covers, dp and turbo. I would say this is the new build.....shootin for 9's.
autoaddictions
Same truck yes. I squeezed every ounce out of the first setup that I ran in myTY. That bested a 10.56 at 129 at 30 psi. I decided to freshen up the bottom end and build new turbo kit with headers ,larger intercooler and a ball bearing 76 mm turbo instead of a 72 mm and try a extremely crazy cam choice. Thats the current set up you see in the pics with stock intake . Ive only made 3 passed at lower boost with that setup and the rear blew. Best pass of the 3 was a 10.6@ 136. at 20 psi!! At the same time ive been building a bowtie motor to take it to the next level. Lets face it a stock block in the 9s isnt going to last. The plan was to get my TY into the 9s then swap the motor to my Stock Syclone and detune it a bit. Make a solid 10sec driver. Then put the monster bowtie in Ty and shoot for the 8s. Ive been acquiring parts for that engine for 2 years. It takes time since everything is a custom part. Not to mention the expense.
So yes same truck, 2 different builds. 18* Bowtie is sitting on a stand right now.
Heres a pic of the first engine combo. Stock manifolds RPM down pipe 72 mm turbo Rpm front mount intercooler.
By fdeninno
BigBadSmoosh
I have an extra rear end gear for a typhoon if you want it.. i know you are going bigger, but this would at least allow you to drive the truck around..
