92TYPHOON937
Re: my turbo 94
making it a real ss i like actually ss will mean somethin to ur truck
first of all i liked to say you have a sweeet truck and im looking to do a similar project and was just curious to as how much it cost you to turbo the truck and what ur hp numbers are? Thanks Tom
i probably had a few grand into the initial setup. that includes using a stock motor and heads, and also includes an aftermarket ecu setup. towards the end i was running 25 psi and while it has never been on a dyno, i would say it was making over 400hp at the wheels. this new setup is a bit more wild
nice nice, im looking into doing this how hard is it to do? i noticed you didnt use any sy/ty parts. How much is a few grand around 3 grand or so?
kinda stupid question,,,but how come you put two pairs of injectors on each side? there is three runners on each side. but you have two together and two together. how does fuel get to the third runner? did i miss something?
super wicked build. i love a bagged truck that looks clean. any progress latley?
aaaaaaaaahhhhhhhhhhhhhhh. ok. that makes sense. so your gonna cut off the extra material? weld it and grind it down?
you mean weld the injectors? when i cut the tops off, i packed them with some jb weld to seal of any possible leaks through the injectors. i figured doing it this way would have lots of people scratching their heads at local shows![]()
