my ty is a dog
92ty201
not sure why but the truck has really no pull to it. i races a friend last night that has a honda civic with an lx non vtec engine in it and he spanked the crap out of me. i tried having a mechanic put it on a scanner the other day b/c the check engine light went on and the scanner said no signal. idk where to start with this thing guys. im used to working on s10 with carbed small blocks, not this injected stuff. if anyone knows a place in or around jersey that knows these trucks real good please let me know so i can drop it off and have them go over the truck and make sure everything is rite. let me know what you guys think.
cloneman315
Re: my ty is a dog
spend about 2 days on here reading,and get datamaster!! I can tell you for sure the truck has some issues without even looking at it,get them fixed before it blows up!!Be smart about it most are not.
92ty201
Re: my ty is a dog
what is datamaster? another thing the truck does is it has a very long start when cold and sometimes when its hot. i replaced the computer today to eliminate that but there was no change in power or the scanner problem. i see all over youtube these trucks are sick even stock. it pisses me off so mutch that i finally have one and i cant even enjoy it.
BigBadSmoosh
Re: my ty is a dog
1) Bring it to someone that knows the trucks
2) tune up
3) fuel pump/Adjustable fuel pressure regulator
4) Scan tool (datamaster)
5) New starter
6) replace any sensors that are causing a problem
7) figure out if you need a new cat
If you are in north jersey, I can help, but i'm not fast (due to not having a lot of free time) and i'm on vacation/busy the next couple of weekends
BoostedSUV
Re: my ty is a dog
I agree with the a above... You definitely need datamaster to see what's going on. I would start by first doing a tune up as stated, plugs/wires/cap/rotor, then Walbro 255lph fuel pump with and Adjustable regulator, and check the IC pump. My truck barely ran 14s until I discovered the IC pump wasn't working, changed it and got it into the 13s! Intake charge temp is very important.
UK-Ty
Ty Crazy
Re: my ty is a dog
Have a look at Tooky's site,www.powertuneplus.com it will give you a good idea what to do including datamaster. It sounds like you have lots of KR (knock retard) so stay off the gas until you give it a tune up and get it on Datamaster. If these trucks run slow DON'T thrash it or you will be picking up bits of motor off the road.;)
92ty201
Re: my ty is a dog
i live in bayonne, rite next to jersey city and newark. first off theres no cat on the truck due to a cheap scumbag preveous owner. i think i found a bit of a problem today, im getting blow through. a mechanic friend of mine said most likely the rings are done. as for the comment the one guy said, i am getting a pinging at heavy throttle. i dont beet on the truck realy but the few times i did it happened. the truck seems to have all new msd wired,cap, and rotor. i also did the starter in it already. and o yea there is no air intake on the truck, just the orange tube with i screen on it... ideot threw the stock one away.
UK-Ty
Ty Crazy
Re: my ty is a dog
Unless you know what your doing big time running with no cat will kill your motor quick. I may be wrong but the way i see it when the cat is missing you have less back pressure so then your turbo will want to spin quicker (over boost) and make your truck run like crap because because the ecu will be pulling timing due to the over boost=runs lean and makes knock then retards the timing to save the motor.
Having said that i have drunk 10 pints of larger so if I'm correct:woot: and if I'm wrong blame the drink.:lol:
powercat6
Re: my ty is a dog
Uk Ty's statements are accurate. This thread discusses catalytic convertors; post number 3 sums it up very well
http://www.syty.net/forums/showthread.php?t=22710&highlight=catalytic+convertor:
powercat6
Re: my ty is a dog
Do you know what kind (brand) of fuel injectors are currently on the truck? If you don't, I would check if I were you. If they are Kenne Bell injectors I would not drive this truck until I knew for sure that a Kenne Bell Chip was not in the ECU. The Kenne Bell chip and injector package was installed in numerous trucks and they are nothing but an engine rebuild waiting to happen. The KB chip WILL NOT retard timing when engine knock occurs and can/will destroy the engine.
92ty201
Re: my ty is a dog
ok with that said is there any company that sells a full catback for the ty? im currently running a home made broke ass setup so that would be a great thing to change. as for the blowthrough, should i even bother checking on everything if the motor is already shot and im gonna have to rebuilt it anyway with all new inj, and upgrade the chip. if i was to rebuild i would probably not do it to stock specs.
92ty201
Re: my ty is a dog
i found a place in toms river new jersey call boostinblazer so im gonna give them a call today to see if they can go over the truck for me. thanks alot for your help fellas. any jersey guys who are in a club and maby would want to add another member im down for whatever. i go to the street races in jersey city during the weekend so hit me back if you would want to come and race some hondas... its on 440 south at the dunkin donuts.
