name that sound. round 957
doomdead
When the ignition is on but the truck is off, theres a odd noise coming from inside the top intake manafold... i 'think' towards the rear. (firewall).... sounds like a slow ticking sound....
keep in mind IC is off, and fuel pump shuts off after a few seconds, so those aren't it.
whadya think
sytyguy
Moderated User
Relay....maybe? They make a "ticking" noise when they start acting up. With the key on, go around front and wiggle/tap the relays & attaching wires and see if you hear/feel one do this. If so, try cleaning the contacts (the gum up sometimes) or just replacing it. Standard #RY-27 is the fuel pump relay and IC relay IIRC.
*EDIT*
In retrospect.....if it's coming from the intake manifold, you may wanna check the IAC. It could be emitting a noise/vibration that could be heard/felt throughout the entire intake. Try resetting it or just replacing it (Standard #AC1).
HTHs
Michael
Falco
My tip is IAC too... Disconnect its connector to check it, but don't forget to plug it back before you start the truck.
HTH,
