need a bin
STORM TROOPER
hello Im trying to get started here with code$59 I have vortec heads stock valves 50# inj gt35r turbo and meth if you have a good bin I would like to try it. tia:tup:
MRKING
New Parts for Old Trucks
Re: need a bin
You can download whatever is available on the actual code 59 website .
WyoSyclone
Re: need a bin
finaly got a bin to idle, WHERE IS AUTOTUNE???????!!!!!!!!:rant:
Autotune is on the Code59 site.... first step is to play with f28 to get it to idle, then go into modifying f29x via autotune for the first 5 or 6 easy drives.... then you may go into manually adjusting f29x.
WyoSyclone
Re: need a bin
k i figured out where autotune was how do I put a file in it? sorry iM retarded..well semi anyway....
There's a tab at the bottom of the file labeled instructions... just follow those - it's pretty easy. Make sure your copy of excel has the 'analysis toolpak' add-in installed.
STORM TROOPER
Re: need a bin
jees like i said retarded is there a video of how to do this? or can someone hold my hand and walk me thru it?
