need A little help locating A wire.
1madgumby
Trying to get the ty. back togather & found A light brown wire with white stripe, not sure were it goes to. it is in the wiring section that goes to the Alt.. Thanks..
Aj.
Norm
Re: need A little help locating A wire.
I'm looking in myservice manual at the wiring section. It shows a tan/white wire from the front lamp harness.It ends up going to a diode and then runs into a park brake switch/cluster lamp.That's the one I found. Hope it helps.
1madgumby
can you send me A pic of what you have in the wireing diagram?
Thanks..
Norm
the wiring diagram is a 6 page fold-out.
93 TY 2185
I'm thinking it's the system ground that goes to the thermostat housing.
