adam92 said:Yeah,kind of,but a closeup view.
See,I never changed the belt on it before,so I loosened the nut on the top tensioner,or whatever it is called,and then I moved the pulley below it to the side,and slipped the new belt on.Then I went to tighten it all back up,and the lower pulley won't stay directly under the tensioner,it shifts to the right a little.I don't think the arrows on the top are lined up at the same spot as before either.
Yeah,I know that now,but I thought I had to loosen the bolt on the tensioner.bezerk said:adam92 said:Yeah,kind of,but a closeup view.
next time...put a wrench on the bolt that holds the pulley, now you are able to release the tension on the belt...
no need to unbolt annything..
