Re: Need advice/help on Ty not starting
OK, I have some more results from troubleshooting on my Ty not starting:
1. Does it crank? YES
2. Is there a 'service engine soon light' with key 'on'? YES
3. Does the fuel pump run for 2 seconds when key is turned to ign, but not 'cranked'? YES
4. If above is yes, turn key on, let pump run until it stops, crank for 10 seconds, stop cranking and listen: Is pump running [until oil pressure from cranking drops]? YES
5. Will it start with the fuel pump jumpered to B+ via the test terminal? DID NOT START
6. What is the fuel pressure at the rail, while cranking? Approx. 45 PSI
7. What is TPS voltage while cranking? Must be less than 2.5 V. ZERO volts with ignition in ON position, ZERO volts while cranking, reference signal tests at 5 volts, and Chilton's says this should be only 1 volt, what could be causing this?
8. Is there spark? Pulled #1 plug wire and cranked, did not see/hear POP of voltage arcing while cranking
9. Is there 'pulse' to the injectors? Check one left, and one right with a VOM. Should be a brief voltage pulse while cranking. YES
Another interesting thing I discovered: I upgraded to a Johnson IC pump and hot-wired it off the yellow wire with a connector to the firewall to run continuously. Now, even with the wire disconnected from the firewall, the pump still runs. Is the relay this wire bundle is connected to now blown? Is there a way to test the relay?
UPDATE @ 12:20 PM - I checked with another fuel pump relay and I was still getting the same symptoms (IC pump still running with no hot-wire hooked up) but I did some research on the pick-up coil. So far, I've changed plug wires, distributor, and coil but it doesn't get any spark that I can tell. I ran through the above tests and had the results that I annotated when I posted this message earlier. When I do crank the engine to attempt a start, there is a strong smell of fuel after cranking. The pressure readings I'm getting plus this smell tells me that fuel is not my issue. Could it possibly be the pick-up coil?
