need answers
The_Butcher
Butchery
hi guys
i have some question and i hope that you answer me
i know this is a stoped question :1 - the typhoon batary where should it be ??
coz my ty batary is in the back of the truck and i didn't know if it is the right place !!
2 -should i change my original fans into a electrical fans
and if it beter to change it could some one give a web site that have this fans
thanks
Stangbeater
How bout it?
Re: need answers
Saad, the stock battery location is passengers side engine bay next to turbo. The stock fan is not bad at all. You could change to elec, but will not see much of a gain if any.
Also I sent you another email about the cluster.
later,
Dameon
The_Butcher
Butchery
Re: need answers
thanks dameon for your reply
thats strange dameon my battary is in back of my truck when you open the tailgate
you will see the battary how could it hapend!!
i thank the last owner thinking of destroy this ty coz 60% of this ty parts is missing:(
when i think of this missing part i feel sorry for this truck, this feeling told me to sell this ty
and there is only 5 ty in kuwait if i sell it i don't think that i will find another one
any way thanks dameon again for the reply and i will chech your email
thanks
The_Butcher
Butchery
Re: need answers
so .. should i take the battary to the original place ??
the truck now hse a elec fans i'm thinking buying the original fan
and you are right dameon there is nothing bad with the original fan
my 1991 s-10 hase the original fan and it's doing good.
dameon where can i find the turbo cooler bracket??
coz the cooler bracket is also missing :(
and where can i find the weatherstrips specially the tail gate weather strips??
VermontTy
Support Our Troops
Re: need answers
Hey Saad....
Many people who have moved the battery did it so they could add a cold-air intake to their truck and not use the stock air intake crossover tube system. Cold air intakes fit nicely in the stock battery location. If you are going to use the intake I'm sending, I suggest moving your battery back to the stock location. To do that, you will need stock positive and negative battery cables and maybe the battery tray (if someone removed it).
The intercooler brackets can be found; just put up a WANTED post for them. The weatherstrips must still be available through the dealer.
Stangbeater
How bout it?
Re: need answers
I have every thing you need, just reply to my last email I sent you.
Adam, Shot me a PM, when you get a chance.
The_Butcher
Butchery
Re: need answers
thanks adam for the information ,so adam is there is any diffrance between the stock original intake filter and the other filter ?? when some take off the stock filter and put the filter that you're talking about if this inncrease the power or what ??
and thanks Dameon for ur reply also , and when i need something i will let you know about it .
thanks again guys
saad
VermontTy
Support Our Troops
Re: need answers
What people add pretty much looks like a box with 2 holes in it, and it goes right where the battery usually is. One hole is for bringing cold air into the engine compartment through the fender well, and the other hole is where the plumbing for the air filter to the turbo goes. Look here.....
http://www.northeastsyty.com/gallery/view_album.php?set_albumName=album06
.....and there are folders that show one kind of homemade air intake system.
The_Butcher
Butchery
Re: need answers
thanks adam for the reply
in your opinion what do you prefer the original kit or the other kit??
and adam you didn't tell me yet about where can i find the weatherstrip give a website if you have.
because ower dealer doesn't have them any more.
and adam what is the size of the typhoon rear axel if you know it?? i find one in summit but i dont know if it is gonna fit my ty .
i know that i'm asking alot of question but i want to learn every thing about the ty
coz i don't want just driving the truck . i want to know what i'm driving.
thanks adam
saad
VermontTy
Support Our Troops
Re: need answers
Personally, I prefer the stock intake unit because I do not like the idea of having the battery inside my truck. People usually change out the stock unit for a cold air intake because helps reduce knock by lowering intake air temperatures, and because you can really hear the turbo whine when it is spooled. I'm not sure that it makes a tremendous amount of power by changing. I'm sorry, but I do not have a website for finding the weatherstipping. Do you not have any at all, or is yours dried up and cracked, or does the rear window squeak? If the window squeaks, it is usually the hinges causing the problem.
Your rear end is the 7.5" 10 bolt with the Eaton Governor Lock differential.
The_Butcher
Butchery
Re: need answers
yes adam my weatherstipping dried up and cracked,coz in kuwait it's reach the (55 c)not just the w/s will dried even people will dried. and about the rear window, when i washed the car the water goes inside it because of the old weatherstipping.
i find the driver and passin door weatherstipping in the
www.LMCtruck.com and www.gm-autoparts.com
but i didn't find the rear door weatherstipping
and sorry adam i mean the rear axel shaft
and i think it's as you said 7.5
adam i heared that the 7.8 will fit thety
i know a little information about the rear axel shaft like the length
but i wan't to know more about coz maybe i will need a new one
this ty gonna cost me alot of :2cents:
and the turbo is gonna need alot of parts
there is no oil coolent pipes its not connected with the cooler
(there is nothing connected to the turbo it's just the turbo)
its need cleaning and alot of works
any way thanks adam for the help
VermontTy
Support Our Troops
Re: need answers
The turbo should have 4 connections, oil to it, oil from it, coolant to it, and coolant from it. Look at the pics in this link for more information. If you do not have any connections on your turbo at all, that is very very very bad.
http://www.syty.net/forums/showthread.php?t=39885
Let me look around and see if I can find any good weatherstripping at the local junkyard; I can put it in the box with your intake when I ship it out if I find anything good.
The_Butcher
Butchery
Re: need answers
thanks adam for ur reply and for yr help
i think i just need the rear door weatherstripping.
really adam i don't kknow what to do with the turbo
adam i will take some pic for my engine and i will send it to you so you can see
what its looks like
and to see what my turbo looks like
really i don't know where to get the parts that missing from my turbo
every one see this truck love it but when they heared about what the last owner
did they advice me to sell it :(
.... thanks adam
