need bins and help!
Quickstop [UK]
Combating adversyty.
I'm going to put in the PROMinator that I mentioned on here, but it is an emulator. I guess I need some code to load into it first of all so can anyone help me out with a stock bin, or preferably anyone with a 20G but I'll take what I can get!
Also, how do I reset the DTC codes on a ctock ECM?
Finally, I have an SES/CEL light that comes on and goes off intermittently. When I looked in DM , I had O2 Sens Fail(13), RICH, LEAN and IAC error.
Would an IAC error go on and off a lot? It was any speed between 30 - 100mph.
thanks,
Mark
SBNova
Re: need bins and help!
Your IAC could generate codes at speed. Most IAC's are open somewhat at cruise believe it or not. You'll need to correct your error codes to tune properly, so I would start sorting through them. There are plenty of stock bins linked in this forum, and on Moates.net in the files section. Look them up under $58 SyTy. To clear codes disconnect the battery, or pull the ECM fuses at the fuse box for a couple of minutes.
Quickstop [UK]
looked in the bins on moates.net and am not entirely sure what to get? 1227749 stock GMECM? Is that right?
there are 4 files in the 4.3ltr 58 section. any specific one or are they all ok?
SBNova
Why dont you download them all and compare them, both visually and behind the wheel. They're free, just check them out.
Quickstop [UK]
I did just that but thought I'd ask in case there were any problems with them. They are labelled in an unclear manner (to me at least) ao not sure if I need a 3 BAR MAP or if they are wideband enabled or what. I thought there was only one stock bin?
Time will tell!! :D
Quickstop [UK]
ok - my 3 BAR sensor arrived the other day (Thanks JWaller!)
Has anyone got a.bin for a 3 bar MAP with everything else stock?
thanks.
