liquidswords88
I pity da fool
I just got my project ty "done". Well the only thing I did not redo was the engine. Well it is now junk, long story for another thread. Anyways I am in the process of rebuilding the engine. I have acquired a set of late 94 l35 heads casting date j034, which I translate into October 3 1994. They should be the ones with the 30degree angle instead of the earlier 8degree. I am looking for a cam to go with them.
I have done many a search recently, and I still am up in the air. It seems every body says run comp 412 or 415 or 422. All with a lift of around .500. Engine will be basically stock except the l35 heads. My current cam is wiped out, so I must buy another. I do not want a used cam. I found a old thread here http://www.nwstp.com/tech/chipstuff/SytyCombination.xls. The two cams listed in the basically stock area seem to be discontinued. Are there any other cams still available that will be drop in cams with l35 heads and under .500 lift? I do not want to change valve springs or guides, I am looking for a drop in cam.
On another note. I had to pull my front differential to remove the oil pan to inspect the main bearings. Depending what it is worth I might sell the whole setup for the right price. Propshaft half shafts,diff control arms the whole lot. I have no idea what it is worth. If it has little value I would keep it, just to keep it with the truck. I am not going to reinstall it. The truck is way more fun with only two wheel drive. So if anybody is interested let me know. It has 96thousand miles and runs quiet and smooth.
