Brian
Aside from the better quality in different waste gate compamies, does size play a critical role for us. I other words, TiAL's 40mm for our stock to average moded builds verses higher HP builds with larger turbos.
I had sent my ATR Delta Gate to Limit Engineering and they opened it up to a 48mm bore size with a 46mm valve. I am not sure if they changed the valve guide material to anything better. I do get a an uneven result and up to 4lbs of creep. The 18lb spring worked fine in my slighted moded build with the t44 turbo, but now with everything shut dowm (base boost) I am 19lbs and up depending on the boost creep.
I am sure less spring would help, but I am looking for something stable, reliable and hopefull the correct size for my higher hp application.
The 40mm may be fine, I just don't have much first hand experience with WG for my type of build. Any advice is very appreciated.
John
