Need crank...any 4.3 works?
TYTILIDIE
METH HEAD
I roasted my crank shaft and need a new one. I called GM and they want $900 for it :eek: :eek: :eek: :syty: So now I am wondering if I can use any 4.3 crank with the Z vin code. Any help is appreciated.
blk00z28
Forced to by choice
Re: Need crank...any 4.3 works?
Your welcome.
Thats why you always have to watch the syty companys on here, they always have good deals. Hell I remembered seeing the stock crank at that price like a month ago when I was dreaming for race motor parts again. :D
Try Me
I found refurbished crankshafts on ebay w/ high quality bearings for the stock motor for $179 plus shipping. Thats dam good as long as the cranks are only like 10/10. any more machining than that and i would be worried about strenght. I will have to get the link on here later when im not at work and blocked from ebay :(
ghettosled
SYTY SUPERSTORE
just b/c it is a "Z" engine code doesnt mean it has the preferrable casting number. Yes they will all work, but you may notice that the syty cranks have a much nicer profile on the counterweights then some of the other cranks. There are a couple casting numbers besides the syty specific that we prefer, mainly due to the finished casting which i like to believe is not prone to cracking or poor balancing.. Just do your research before you buy the cheapest "Z" engine code crank you can find.
and Try Me, there add says "name brand" bearings not "high quality"...
cloneman315
i thought the only diff was one of the journals was drilled someone told me ,is there a big diff between any of the cranks as far as strenght goes?
Loeryder
14088639 is the only part# I can find for it.
It would be nice to post up a list of preferred GM part #s for stuff like this.
TYTILIDIE
METH HEAD
Im still not sure shat I am going to do about my motor. It sucks cause my spare car is an 88 Ford Taurus and it broke down the day I started to use it. Hey, it was free. Anyway, I am flat broke right now and its not looking good for the rest of the winter for me so I guess Ill be sitting on a broke down truck for the next 4-5 months making paymentys on it. Thanks for all the info guys,. At this point Ill probably take the motor out, survey the damage and do a little at a time.
cloneman315
any info on the diff on cranks i checked the vault but is there really a big diff if any?anybody
sean
i have a nitried crank that i bought from mike that's up for sale
