cat-vi
Ty Wannabe
Hi,
I felt a cylinder was not pulling as it should, slightly vibration felt as well, all spark plugs looking realy good, took a leakdown test, all cylinder between 12-15% at cold engine except cyl.No.5 with 42% blowing out of the intake valve. So I have to pull the cyl.head, What do you guys recommend, uppgrade to vortec from whatever cyl.head I got, according to the guy I bougth my project from the cylinder heads was ported, I can read off this No. in the valetrain area, 10144103, C081, S01, any ideas if this heads are worth to recond.? the block is partially filled, eagle rods, forged pistons, PT52 turbo, Air to Air cooler, #50 nozzle, 9/11 3200 rpm stall.Alky controll to be installed, BS3 ECU, Any advice would be highly appreciated.:2cents:
