heavy breather
FBI enforcer
I am trying to run DM to solve a few problems on a SY. I bought an IBM thinkpad, have the cable, and the program running on the laptop. I can't seem to get the laptop to communicate with the truck.
When I try to record a run, I get the "no pcm sync" message. I am assuming this means I need to adjust the serial aldl data timing. So, I go to work changing timing settings. In case you never counted there are 500 possible settings.
I thought maybe it would be able to communicate in a certain "range." SO, I set out jumping by 5. ie go from 0 timing to 5, then "test com". The same message came up after over 130 different trials. "adapter ok, no ecm" (error 1) So, I start from 500 changing the value by 1 down toward 0 again. I just can't point and click anymore today.
Does anyone have any clues how to tackle this problem? Is there an easier way to find the timing value? Am I even addressing the correct problem? Can anyone suggest a range that might be more likely to work?
