Need help finding a economical IC pump
tydye
Banned
Ok after searching searching.................. i get allot of threads post, most in which are older, and links showing to items not showing on ebay or dead links in general.
i wanna replace the IC pump and looking to save a few bucks, i read somewhere users on the board sell them for better prices, so i would like to find out what its gonna cost me and from who. i found some used the cobalts ss pump so i looked into that but seeing if there any other options etc... thx in advance.
WyoSyclone
Re: Need help finding a economical IC pump
Grainger has them, as well as RV supply stores....probably the two cheapest places to get them.
2theStore4Milk
I recently ordered and received Johnson CM30P7-1 pump from Ron Gregory at Auto Performance Engineering. It was $145.00 shipped. That may seem expensive, but it went right into the OEM bracket with no modifying and it should last a long time.
http://APEusa.com
On my buick I use a GM pump which uses an injector plug, works great, the one i use was made for the minivans for rear heat and flows around 7gpm. This link has the GM replacement which is made by bosch , very similar (if not identical) and used on the new cobalts. This is the one we've found to be the most reliable, especially if you when we add ice at the track.
http://zzperformance.com/grand_prix/products1.php?id=425&catid=139
tydye
Banned
cool, its pricey though eh? $175 etc
Syclone #1721
I LOVE 4UM SUPERSTARS
I use a Ford Lightning SVT intercooler pump....fits in stock location...is intended to be used in this application and it suposedly flows 9gpm....I think it was like $100 on ebay...uses an injector plug as well...I mad a nice pigtail with the wire from the old one.
tydye
Banned
hmm thats cheaper then others for sure. ill search ebay
Syclone #1721
no problem...I know you get alot of heat for not searching or not searchin enough but for lack of better words, the search blows. I have no problem talking about the same things over and over again....
tydye
Banned
yea im kinda the same way. most of the searches i do and open threads and posts, have so many dead links its pathetic lol.. like on other forums i used to go regular basis, there were some good help threads that were updated as time went on. ohwell i have no problem searching but like u said it gets irritating getting no where lol on a side note seems whenever i search i end up seeing other interesting things i wouldnt have found without that search lol its a matrix i swear! im reading your thread now. :tup:
tydye
Banned
ok so i removed the heat exchange unit and low and behold it already has a shurflo pump on it, other then re-setting the leaky threaded fittings ill redo with new pipe tape etc..
the problem i have is the fuse for it behind the alternator keeps blowing, now i am gonna flush the heat exchanger with clr mixture to clean it up hopefully, but whats the chances my pump is toast? to why it keeps blowing fuses? it seems to work good for the short time,. could it all just be that i have a clogged heat exchange? any recommendations? i read it can run dry etc. could i hurt it if i just run the pump without being connected to the heat exchanger? so i can see how long till the fuse blows? before it would blow in less then 15 minutes etc. im talking about just with the ignition key to the on position being hot wired etc.. also you think if i run a clr mixture through the pump help or hurt it?? thanks guys! pics below...
tydye
Banned
ok its late so i didn't notice on first pics, but pic below shows an up close view of some exposed wires that must have been pinched worn on the pump etc...( sorry if the pics aren't the clearest its my iphone 3gs with poor lighting ) i guess its possible thats whats blowing the fuse, i wasn't sure but when i would take cap off upper air charger i can see it pumping ( before i removed anything ) so it did have flow. i guess ill fix the wires clean everything up and install and test, but still gonna clean the heat exchanger with clr mixture, but what about running clr through the pump. any insight to that being safe to the pump?
tydye
Banned
well if anyone is following, after getting everything flushed and put back in and the exposed wires on the pump fixed, i ran it for 30 minutes how i normally run it and no fuse blowing! usually it would do it less then 15 minutes. the wire must had been grounding up there and looking at it seemed close to the crank pulley, so i zip tied everything up and seems good. i will see how it is on the way to work tomorrow 40 min drive etc..
WyoSyclone
It'll be fine... I've used it a lot to clean out 12-volt solar driven pumps on in-floor heating systems.. if anything the pump will like it. You might have to do the cleaning/flushing process a few times. If you can hook up an extended piece of hose and run the entire flow through a filter (like you use on sprinkler systems) it will filter out all the crud and you'll be done in no time.
tydye
Banned
yea good idea, i think when i get back on it i will do that, i was reading on shurflo pump site the pump can run dry to so that is good to hear.
Ken
Scalarrthu
This thread proved to be very convenient for me. Odly enough, my IC pump let go today while I was driving it, so this was just the information I needed.
Best of luck with your fix...sounds like you got it taken care of.
tydye
Banned
good to hear paul! and ofcourse come back if you need help lol. like he said some of us dont mind repeating stuff i guess as long as we dont do it in every thread lol. but the search is ofcourse still useful.
