Need Help - Installed new complete harness into sy
Syclone0565
CustomMulticades.com
Hello, I am installing a complete new wiring harness into my syclone. I have everything hooked up except 3 things. I have the wiring diagrams for the Sy/Ty's but I can not figure out where I am going wrong on these plugs. I have the column hooked up have a couple questions for the wiring experts here.
First picture is the column flat harness. The new harness had all the wires for the column marked. I installed them all but have two extra on my column. As you can see in the picture the wires I need help with is the light green with white stripe and the tan with white stripe. What do these go to? Are they power, grounds, or maybe the cruise control that I no longer have installed ???
OK, This is a harness that comes out of the column also and I have no idea on this one.
This is the headlight dimmer switch panel on the left side of the steering wheel on the dash with the two factory plugs still attached for reference. Can someone give me the breakdown so I can tie them into the new harness. My new harness has two wires that go to this. One is labeled Headlight power and is a bigger gauge than the rest of the harness wires and the other is the Dimmer power wire that is also a bigger gauge than the rest. I believe the Headlight power will tie into the Red bigger gauge wire in the pic on the headlight switch. As for the others..... ????? I have no idea. Anyone know ANY and all help would be greatly appreciated.
syclone0517
Re: Need Help - Installed new complete harness into sy
okay. the Tan and light green wires at the base of steering column are connected to the "Key in ignition" sensor. The green wire connects to the "audio alarm module" in the convenience center. The Tan wire connects to your door ajar switches. I'll look into your other issue.
syclone0517
okay. on the headlamp switch. red wire is connected to battery junction block.Hot 12V at all times. you know the one on the fire wall under hood. The yellow wire connects to the head lamp high/low dimmer switch on steering column. The orange wire comes from T/L CTSY fuse.Hot 12v at all times. The brown wire is your park lamp circuit.//// On the dimmer switch the green wire supplies variable voltage via rheostat "dimmer" to the "INST LPS FUSE". The black wire is connected to ground. The white wire is connected to your courtesy lighting {foot well lighting/dome lamp ect.} white wire is toggled to ground when you roll the rheostat all the way to the detent position. The brown wire is from the park lamp circuit. 12 volts with park lamps on.
Syclone0565
All taken care of
Thanks to all that helped.
Will
