Need help Intake gasket procedure please!
Neelsonwheels
Hi guys I developed an intake gasket or bolt failure.
The truck started missing on the way home and now barely runs.
I have coolant on the top of the manifold that I believe is coming from the bolts.
I need the best way to replace these. Which sealant what torque so on.
These are vortecs by Waller. I don't have a smoke and the oil looks clean so I think I will be okay. The coolant didn't get to the oil or bearings.
Thanks
Neelsonwheels:(
sytyguy
Moderated User
Re: Need help Intake gasket procedure please!
I was just going to reply to your PM, but I'll do it here. I have everything in stock EXCEPT the FelPro 1203 gaskets. Out of stock on those right now. I'll be glad to help you out with the rest, but if Mike or someone else has it all on the shelf, their "package price" will probably be better than getting some from me and some from them.
jwaller
Evil Genius/SyTy Guru
it's pretty simple stuff, same and when you put it together the first time. I have a set of intake gaskets and use same rtv on bolts as you did on the front and back of the intake. if it's only a bolt then you don't have to R&R the intake to fix it. but if you do remove the intake then drain the coolant before you do.
I've installed and removed and installed (I've lost count :rotf:) mine without leaks and my trick is to use Permatex Form-A-Gasket #2 around ALL ports on both the heads AND the lower manifold. Even at the rear. Black RTV across the valley and red silicone on the bolt threads, torque evenly from center out. Never leaks.
Neelsonwheels
thanks for the tips I hope I can get this done soon.
I am supposed to goto the track on October 8th.
Want to see if 11.00 is doable.
ghettosled
SYTY SUPERSTORE
use "right stuff" around the water jackets, and black RTV on the threads.. Make sure you plug the original bolt holes in the heads. should be good. If the intake was not machined properly or too much material was removed after welding it may be more difficult to seal.
