Need help isolating an oil leak.
IDRVSLO
When Hell Freezes Over
Ok so I have owned the Ty for a little over a month. From day one I noticed a fairly significant oil leak. I got under the car and cleaned away where the oil was dripping from. Seemed to collect in the vicinity of the left side control arm mounting point. In a month it has gone down a total of 2qts. No burning, just leaking. What are some of the common spots this can occur? Any suggestions? I also have a misfire but still need to change the wires, cap, rotor and plugs. That will happen this weekend. Thanks for any help.
Scott
Re: Need help isolating an oil leak.
When you say left side do you mean drivers side?
Assuming you might mean pas side (left if looking from the front) then I'd suspect the turbo drain.
leroy
Suspect the oil lines for the remote oil filter.
Jim
