Need help on rear wedge degree.
Big Mike
When I bought my truck I am the 3rd owner there was no wedge between the rear axel and the leaf springs. I was told the 1st owner had the truck lowered with blocks and the 2nd owner had the truck redone to stock ride height. Who ever did the work did not know enough to put the wedge back in.
I need to know the degree of wedge or GM part number for the wedge that is used
on stock Syclones.
GM has no idea or listing for this part separately if one exsits.
I looked at a newer S-10 Exreme on the dealer lot but there was no wedge there.
Did all Syclones come with a wedge or was it a truck to truck setup???
Thanks.
Mike
jwaller
Evil Genius/SyTy Guru
Re: Need help on rear wedge degree.
I have several stockers I'd be happy to measure when I get home tomorrow.
Big Mike
Waller how many degrees did you measure? So far I have only came across 2,3,4,6 Degree wedges at the local store.
GTMOTORSPORTS
so do you guys run degree wdges or is the pinion angle set at 8 degrees when the pad is welded to the axle tube from the factory.
Big Mike
Thanks for all your help. Could you measure your wedge and give me the dimentions?
