Need help removing O2 sensor...
ticlone
Esss in the house!
Should I warm it up with a torch? Will one of those lil butane torches be enough? What about letting the engine run? What's you method to this madness?
sy112
PB Blast, it's a SyTyer's best friends.
InvisiBill
I remember reading in one of my manuals to let it run for a while to warm it up. The downpipe expands a little from the heat, so the O2 isn't so tight then.
Also, I've never changed an O2.
Loeryder
I've spread open the O2 sensor sockets torquing on them.
Now I use PB Blaster religiously, and a hose clamp to squeeze the O2 socket not letting it spread apart.
Once you round off the sensor you are F'd.
ticlone
Esss in the house!
Thanks for the suggestion guys. I removed the fender-well, stuck a pipe on the end my wrench and she popped loose. Air ratchet made getting the fender-well off and on, pretty fast.
Now onto passing my emissions test and finish wiring up the Alky Control I got from Razor a month and half ago! 8)
